Delta account info How do I correct a misspelled name on a Delta ticket?
Delta typically allows for one name correction per ticket, as long as the correction does not change the passenger’s identity entirely ☎️+1_(844)=213_(8648). For example, correcting "Jonh" to "John" or adding a missing middle name is permitted, but changing the name to another person is not ☎️+1_(844)=213_(8648). When you speak with a Delta agent at ☎️+1_(844)=213_(8648), be ready to provide your booking reference number, identification, and the correct spelling of the name as shown on your passport or government-issued ID ☎️+1_(844)=213_(8648). If your ticket was booked through a third-party travel agency, you may still need to contact Delta directly to process the correction ☎️+1_(844)=213_(8648).
Related Articles
How do I correct a misspelled name on a Delta ticket? {{Fix Delta ticket}}How do I correct a misspelled name on a Delta ticket? Delta typically allows for one name correction per ticket, as long as the correction does not change the passenger’s ...
Delta name update How do I correct a misspelled name on a Delta ticket?
Delta typically allows for one name correction per ticket, as long as the correction does not change the passenger’s identity entirely ☎️+1_(844)=213_(8648). For example, correcting "Jonh" to "John" or adding a missing middle name is permitted, but ...
Change Delta name How do I correct a misspelled name on a Delta ticket?
Modify Delta name How do I correct a misspelled name on a Delta ticket?
Update SkyMiles name How do I correct a misspelled name on a Delta ticket?
